Thank you for the reply. Is there a common cause that would trigger this code? After reading all the horror stories about these transmissions, I'm already assuming the worst...P0841 is a transmission pressure switch code, which I guess isn't too surprising given the relatively high mileage. A lot of times one problem can light up multiple error codes on the dash, so I'd look into this first.
Yeah...the transmission pressure switch...Thank you for the reply. Is there a common cause that would trigger this code? After reading all the horror stories about these transmissions, I'm already assuming the worst...
You have in the Duralast battery what is called a Flooded Lead Acid Battery (FLA). The batteries most people are getting or GEN 5 ODYs are the Absorbed Gas Material batteries. Depending on what manufacture you buy will have a higher Cold Cranking Amp (CCA) output. They do better in cold weather, the only downside of them is they cost more and cannot be used in a older vehicle that does not the correct charging system for this battery and you cannot use an older battery charger on it. I have not heard of a battery with a Proprietary carbon additive for faster recharge that increases battery life. Sounds like a gimmick IMHO.I believe it’s a duralast platinum
I’m guessing it’s inside the transmission and a shop will have to tear it apart? Debating on having it towed to a transmission shop or to the local Honda dealer at this point.Yeah...the transmission pressure switch...
Assuming you have a Touring/Elite, you'd have the in-house Honda 10 speed AT. I'm not sure if they changed it with this AT (I doubt it, but with Honda these days you never know), but with their past ATs, the pressure switches were located externally and could be replaced pretty easily.I’m guessing it’s inside the transmission and a shop will have to tear it apart? Debating on having it towed to a transmission shop or to the local Honda dealer at this point.
Well that’s a bit of a relief. It’s actually the EX-L so from what I understand that’s the 9-speed. I know it doesn’t have a dipstick to check levels. Hoping it’s still external. 😬Assuming you have a Touring/Elite, you'd have the in-house Honda 10 speed AT. I'm not sure if they changed it with this AT (I doubt it, but with Honda these days you never know), but with their past ATs, the pressure switches were located externally and could be replaced pretty easily.
Ah. EX-L. The issue with that is the AT isn't made by Honda. So I wouldn't be surprised if it's not external. But I don't know.Well that’s a bit of a relief. It’s actually the EX-L so from what I understand that’s the 9-speed. I know it doesn’t have a dipstick to check levels. Hoping it’s still external. 😬
Honda just called and said the transmission needs replaced. There diagnostic tree tool says that P0841 code options are 1. troubleshoot an electrical wire/connection or 2. replace the transmission. The day before talked to a few transmission shops that were recommended. Both Honda and transmission shops said these new transmissions aren't meant to be opened or worked on. Basically if it fails, replace it to the tune of $7,480.Ah. EX-L. The issue with that is the AT isn't made by Honda. So I wouldn't be surprised if it's not external. But I don't know.
That is a bunch of bull-stuff they are saying to you. However your Honda dealer nor any other car dealer will work internally with the transmission. And the price they are quoting you is full retail price.Both Honda and transmission shops said these new transmissions aren't meant to be opened or worked on. Basically if it fails, replace it to the tune of $7,480.
I paid 9.5k for my replacement 10 speed at 69k miles.Honda just called and said the transmission needs replaced. There diagnostic tree tool says that P0841 code options are 1. troubleshoot an electrical wire/connection or 2. replace the transmission. The day before talked to a few transmission shops that were recommended. Both Honda and transmission shops said these new transmissions aren't meant to be opened or worked on. Basically if it fails, replace it to the tune of $7,480.
