If you're out of warranty and don't have an extended warranty, can you just take it to the most reputable, non-dealership, shop in your area?Oil filter and oil change: $79.99 - Reasonable for a dealership
Engine air filter and cabin air filter: $59.99 - These 2 filters, OEM Honda, are $45 total if you buy from an online dealer.
Tire Rotate: $19.99 - Reject this charge if you get wheel/tire balance. They take the wheels off the car anyway. I've rejected this dealership attempt before and they didn't push back -- they just said, "You're right" and took it off.
Tire Balance: $39.99 - Reasonable for a dealership
Tire Alignment: $139.99 - Would expect more like $120 from a dealership
Transmission fluid and filter: $539.99 - I've never spent more than $200 on a transmission fluid exchange/flush on a vehicle - but also never done it on a 9/10spd modern transmission like this. Would get another dealer quote on that (just call them) to compare -- or wait for some more input from people here.
And this is why my alignment intervals have gotten longer. It's hard to find a place that does alignment that won't try to upsell you, so I end up having to wait until I go to my regular mechanic for some kind of service (he's somewhat far away from where I live, else I'd just go there whenever I needed an alignment) and then I can have him do it, since I trust that he won't try to upsell me.Get a lifetime alignment at Firestone. I get it done twice a year for 9 years now, and something is "knocked out" every visit. I've had at least18 alignments for the $189 I paid when purchased.
Tires I buy at Discount Tire. They rotate and rebalance twice a year or more if I feel a vibration... all at no charge.
What Honda calls a flush is just a 3x drain and fillIs there a transmission filter in Odyssey, and need to be replaced regularly?
Does Honda maintenance schedule require a transmission fluid flush? I thought just drain and fill, no?
No, the computer senses where the sensors are located and updates accordingly. No need to reprogram.After tire rotation do the TPMS sensors need to be reprogrammed so the car knows how to display the tire pressure and mounting location?
While I appreciate all the comments about the cost of THIS job.... you are apparenlty looking at 50,000 trouble-free miles, which cost you about 1.76 cents per mile.... interesting.Went in for the 50k service as recommended by the instrument cluster. The system displayed the "123" service code.
Dealer quoted the following:
Tire Rotate: $19.99
Total quote: 8 hours and $880 before taxes.
I passed on the transmission flush and filter. Service advisor said it "was recommended but wasn't necessary", but he'd knock 10% off if I did it today. Shady.
It is illegal for any manufacturer to void your warranty if you don't have the dealer service the vehicle.Aside from the transmission flush, nothing really seems that far out of line for the dealership premium. Yes, it's expensive when you do all these things at once... but they need to be done... So I don't really get the comparison to a BMW. Add $50 to all these numbers and you'll get the BMW service cost. 🤷♂️
I have a drain and fill done on my 05 at about 8k when I change my motor oil and filter. I have about 210k with no problems with tranny. I was told years ago by an experienced mechanic I trust that to allow tranny oil to go 50 k is asking for a dirty tranny and early failure. He told me to inspect the magnetic drain plug for black sludge. The tranny holds about 8 quarts and a drain and fill only gets 4 quarts out so it’s not so radical as you think. We have several Odysey owners in the family and we all notice smoother shifting after an 8k drain and fill. I have heard nightmare stories about flushes knocking loose so much crud at one time in very dirty transmissions that they get much worse.Most of this stuff is stuff that should be done at this time, but things like the cabin air filter and engine air filter you could easily do yourself.
The transmission fluid is important..usually it's recommended to do every 30k miles, though I suppose it's longer for the newer gens.
Local guy who has wheel alignment shop looked at my 05 because it was pulling to the right. After measuring he showed me that alignment was perfect and asked me if I cross rotated tires. He told me I had under inflated tires, and told me to do front to back only on these tires. He said that Odys needed alignment only after accidents and or suspension damage. He refused to charge me. I changed the tires around like he told me and pulling completely stopped. Was I blessed or not? He also told me that Honda shocks get huge mileage and rarely need changing unless leaking or bent. Uneven bouncing is a sign of a blown shock.No... Still don't understand, why client should pay two times.
Lift vehicle, remove wheels, put on stand, balance it, remove from stand, put your helper on the position, he will tell you where to put wheel, put wheels back.
Tire Rotate: $19.99
Lift vehicle remove wheels, put your helper on the position, he will tell you where to put wheel, put wheels back
So, can you explain now, why client should pay for rotation, if he did balancing?
May be technician did extra work?
Honesty, if some shop would try to make me pay this way, I would ask them to do full process for balancing including installation wheels, torque them and put vehicle on the ground, and after to do tire rotation. So again lift vehicle remove wheels, rotate, put wheels back etc...
If i pay twice, job must be done twice.
Hope my explanation is clear, with my weird English.
See my comment below about 8k 4 quart drain and fills.Wheel alignment isn't part of the prescribed service, unless they observed uneven tire wear. If so, they should have explained this to you. If not, they should not have added this item.
Tranny fluid and filter is prescribed service. Their dismissing it as "wasn't necessary" was irresponsible. Sure, the car won't stop running if it's not done, but it's factory-prescribed preventative maintenance that will add many miles to the life of the car.
This seems to be an unscrupulous dealer. Start again with a different dealer and compare before having anything done.
Well this person who does front-end alignments must have been only working just a day. You can cause alignment problems by hitting a curb, or driving through a chuck hole that was way too deep. Even frost heaves in abutment at bridge approaches. Heck drive over a speed bump to fast and there you are out of alignment. None of these items have to cause suspension damage or they can.He said that Odys needed alignment only after accidents and or suspension damage.
Don't be sorry for "being long winded" if you have something to say and is on subject type away!Thanks, sorry for being so long winded.
Tire Rotate: $19.99
