1 - 17 of 17 Posts
it has been giving me some problems. Mechanics reset the codes but now this new problem. Need Help
What were the codes?:unsure:
Is the Check Engine light on again? Then get the codes read from an Auto Parts store.
I can't figure out what's wrong because my Crystal Ball is showing an id10-T code! :(
Reactions: jiantao
My crystal ball, my code.:ROFLMAO:
Your Elite, what's your code(s)? :unsure:
We can't help you with your problem without information. That is, unless I figure out how to fix my crystal ball!
You say problems and then new problem. Without better detail nobody can help.
Reactions: jiantao
I had this 2002 Ford Focus with this wacky "split port induction" engine once. It never had a code. One day, on a family camping trip three hours from home, we stopped for gas. I filled it up and went into the store. On my way out and back to the car, my wife starts it. There's an immediate racket like a giant fork in an even giant-er garbage disposal, then a few seconds later it stalls. It starts up again and runs for a few more seconds, this time the sound is a tenth of its original volume, and the engine then dies for the last time. Cranked forever after that with not a sign of any further life. The end.
Yeah, we need the codes.
The computer has probably limited the engine to 2000 RPM because of the codes. It's a result of the codes, not a cause.
Did the mechanic do any work before resetting the codes, or did he/she just reset the codes?
Administrator
Nope, didn't help. My crystal ball is still showing id10-t. :( Thanks anyways bandit400!
And @samdaking seems to have disappeared, doesn't want to answer any of our questions!
I had a brand new Civic Hyb. in 2008 which had a control on the transmission which sent a sync signal to the engine, or so I was told by a dealer. The control on the transmission was not sending a correct signal to the engine and it would not go over 40 MPH with very high RPMs. It was fixed by a dealer who paid most of my towing charge.
Calling you MF was an early clue to his charming demeanor.
My friend's Toyota had a similar problem. Turned out it was the floor mat got stuck under the gas pedal and wouldn't allow full travel.
Not likely but worth checking.
  • Haha
Reactions: Juggawut
1 - 17 of 17 Posts
