Status
Not open for further replies.
1 - 2 of 2 Posts
Super Moderator
Here is what is required to be able to access the Honda/Acura links:
1. Open this Honda eStore link: Honda online store : 2019 Odyssey Accessory installation (DIY) instructions
2. Open any Honda/Acura link
Note: The Honda eStore link allows access to the Honda/Acura links for ~ 1 day, otherwise you will then get an error message. If you get an error message, just follow the steps again to regain access.
TSB 18-036 - 2019 Odyssey: PDI Information
Applies To: 2019 Odyssey - LX, EX, EX-L, EX-L with Navigation and Rear Entertainment System, Touring, Elite
http://www.urvi.net/forumfiles/SB/A18-036.PDF
LinkDeny
TSB 18-037 - 2019 Odyssey: PDI of the Navigation System
Applies To: 2019 Odyssey - All with Navigation
http://www.urvi.net/forumfiles/SB/A18-037.PDF
LinkDeny
TSB 16-013 - High Pressure Fuel Pump Chirps
Applies To: 2018-19 Odyssey - ALL - ALL
http://www.urvi.net/forumfiles/SB/A16-013.PDF
LinkDeny
TSB 16-087 - Transmission End Cover Leaks (9-Speed A/T)
Applies To: 2018 Odyssey - LX, EX, EX-L - ALL
2019 Odyssey - LX, EX, EX-L - From VIN 5FNRL6H..KB000031 thru 5FNRL6H..KB021038
http://www.urvi.net/forumfiles/SB/A16-087.PDF
LinkDeny
TSB 17-075 - Service Manual Update: Sliding Door Position Adjustment
http://www.urvi.net/forumfiles/SB/A17-075.PDF
LinkDeny
TSB 18-025 - MIL Comes On with DTC P0300-P0306 or P219A/B
Applies To: 2018 Odyssey - ALL - ALL
2019 Odyssey - ALL - From VIN 5FNRL6...KB000001 thru 5FNRL6...KB026674
http://www.urvi.net/forumfiles/SB/A18-025.PDF
LinkDeny
TSB 18-086 - Service Manual Update: F-CAN Bus Connected Unit Check
http://www.urvi.net/forumfiles/SB/A18-086.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A18-086/enu/A18-086.PDF
TSB 18-107 - Safety Recall: 2019 Odyssey SRS Unit
Applies To: 2019 Odyssey - Touring and Elite - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A18-107.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A18-107/enu/A18-107.PDF
TSB 18-125 - Noise from the Front Driver Door Speaker at 1500 RPM
Applies To: 2018 Odyssey - Elite - ALL
2019 Odyssey - Elite - From VIN 5FNRL6...KB000001 thru 5FNRL6...KB056230
http://www.urvi.net/forumfiles/SB/A18-125.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A18-125/enu/A18-125.PDF
TSB 18-128 - Safety Recall: Power Sliding Door Rear Latches
Applies To: 2018-19 Odyssey - ALL except LX - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A18-128.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A18-128/enu/A18-128.PDF
TSB 18-129 - Safety Recall: Soft or Low Brake Pedal
Applies To: 2018-19 Odyssey - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A18-129.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A18-129/enu/A18-129.PDF
TSB 19-022 - Rear Climate Control Panel Buttons Do Not Work
http://www.urvi.net/forumfiles/SB/A19-022.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-022/enu/A19-022.PDF
TSB 19-023 - High-Pitched Noise from the Heater Case
Heater Case Mis-alignment
Applies To: 2018 Odyssey - ALL - From VIN 5FNRL6H...JB000001 thru 5FNRLH...JB047001
Blower Motor Only
2019 Odyssey - ALL - From VIN 5FNRL6H..KB000001 thru 5FNRL6H..KB023543
http://www.urvi.net/forumfiles/SB/A19-023.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-023/enu/A19-023.PDF
TSB 19-028 - Power Sliding Door Reverses Direction When Closing
Applies To: 2018 Odyssey - ALL except LX - ALL
2019 Odyssey - ALL except LX - From VIN 5FNRL6H..KB000001 thru 5FNRL6H..KB022148
http://www.urvi.net/forumfiles/SB/A19-028.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-028/enu/A19-028.PDF
TSB 19-043 - Safety Recall: 2018-19 Odyssey Battery Terminal Inspection and Transmission Replacement
Applies To: 2018-19 Odyssey - Touring, Touring-Elite - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A19-043.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-043/enu/A19-043.PDF
TSB 19-045 - Safety Recall: 3.5L V6 Timing Belt
Applies To: 2019 Odyssey - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A19-045.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-045/enu/A19-045.PDF
TSB 19-046 - Safety Recall: 2018-19 Odyssey Check Park Mechanism (Snapshot
Upload Required), Battery Terminal Inspection, and Update TCM
Applies To: 2018-19 Odyssey - Touring, Elite - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A19-046.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-046/enu/A19-046.PDF
TSB 19-052 - Horn Does Not Work
Applies To: 2019 Odyssey - LX - From VIN 5FNRL6H2.KB000001 thru 5FNRL6H2.KB113315
2019 Odyssey - EX - From VIN 5FNRL6H5.KB000001 thru 5FNRL6H5.KB114305
2019 Odyssey - EX-L, EX-L with Navigation and Rear Entertainment - From VIN 5FNRL6H7.KB000001 thru 5FNRL6H7.KB113825
2019 Odyssey - Touring - From VIN 5FNRL6H8.KB000001 thru 5FNRL6H8.KB113015
2019 Odyssey - Elite - From VIN 5FNRL6H9.KB000001 thru 5FNRL6H9.KB116104
http://www.urvi.net/forumfiles/SB/A19-052.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-052/enu/A19-052.PDF
TSB 19-071 - Auto Idle Stop Does Not Work (BMS Inhibited)
Applies To: 2018-19 Odyssey - Elite, Touring - ALL
http://www.urvi.net/forumfiles/SB/A19-071.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-071/enu/A19-071.PDF
TSB 19-073 - MIL Comes On with DTC P0430 or DTC P0430 with P030X, P219A or P219B (Without Software Update)
Applies To: 2018 Odyssey - ALL - VINs starting from 5FNRL6...JB014845
http://www.urvi.net/forumfiles/SB/A19-073.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-073/enu/A19-073.PDF
TSB 19-096 - Product Update: Display Audio Clock Off by 1 Hour
Applies To: 2018-20 Odyssey - ALL Except LX - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A19-096.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-096/enu/A19-096.PDF
TSB 19-097 - Service Manual Update: MOST Bus Network Failure Log
Applies To: 2018-20 Odyssey - ALL except LX - ALL
http://www.urvi.net/forumfiles/SB/A19-097.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-097/enu/A19-097.PDF
TSB 19-124 - 9-Speed A/T Hard Upshift with Steady Acceleration or MIL On with DTC P0716
Applies To: 2018-19 Odyssey - LX, EX, EX-L with 9-speed A/T - ALL
http://www.urvi.net/forumfiles/SB/A19-124.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-124/enu/A19-124.PDF
TSB 20-012 - Safety Recall: Third Row Accessory Power Outlet
Applies To: 2018-20 Odyssey - EX-L, EX-L with Navigation and RES, Touring, and Elite - Check the iN VIN status for eligibility
Super Moderator
Discussion Starter #2
Added new TSB 20-012 - Safety Recall: Third Row Accessory Power Outlet.
1 - 2 of 2 Posts
Status
