Have been Googling a long time but have not been able to find a diagram for fuse box A in the engine compartment. This is the fuse box on the passenger side of the engine compartment.
I have the "list" of fuses in fuse box A from the owner's manual. What I'm trying to find is a diagram of the layout of "fuse box A" with numbers on all of the fuse locations. The picture on the underside of the cover is so hard to see so trying to find a printable diagram.
Anyone have a link to a diagram? Thanks.
In case you can’t find it here, For $10/day you can get access to Honda online service manual that includes all wiring semantics etc. You can save things as PDF, they let you print (send to printer or save as PDF)
2019 Odyssey EX
I took a picture of "Fuse Box-A" that's under the hood on the passenger's side.
I also took a picture of the layout that's under the fuse box's cover. Was white print on black cover so inverted the picture to get black print on white.
I measured which fuse locations always have +12 volts and which fuse locations only have +12 volts when the ignition is on and the engine is running.
Here's an image of the results:
161330
Hope other 2018+ Ody owners find it helpful,
Raptor88
