1 - 2 of 2 Posts
While driving 70 mph+ on interstate highways on smooth asphalt, I feel a vibration on the steeling wheel that comes and goes every 0.2 - 0.3 miles dependent on speed. I have tried to turn-off climate control system, eco mode and lane assist with not change in vibration issue. It is very annoying for a new vehicle. Dealer mechanic tried rebalance and rotate tires no luck. I took it to a second shop and had the tire checked ~ they checkout at zero balance. So the dealer brought in drive trans Master specialist and I was told he experienced the same vibration not only on my car but also on another Odyssey in stock. He contacted Honda technical main support and their response was they have not logged this type of complaint so the vibration must be a characteristic of a 2019 Honda Odyssey. They suggested keep checking with the local dealer for any technical bulletins. This is very disappointing response. I have owned 4 previous Honda Odysseys and none of them had this vibration issue. HELP!
Have the exact same issue from day #1. This is our 5th Odyssey Elite; our previous 2015 was dead smooth.
The dealership tech worked on it, carefully balanced the wheels. That helped, but the issue you describe persists. So annoying. But good to know I'm not alone.
1 - 2 of 2 Posts
