I have heard this concern before and I myself have experienced it with my 5-spd Ridgeline. I catch it when I am at a constant speed and the transmission is about to upshift, but I hit the gas enough to cause it to downshift. The hesitation is because of the 'perfect' scenario of things to go a bit weird.
Your tire squeal is the throttle position dictating the proper gear, and the harsh engagement due to it being 'inbetween' gears. This happens to every single transmission under low speed, low engine load, and high throttle position. Similar to the clunk one would experience when in reverse and then going into drive while the vehicle is still in motion.
First off, what the dealership told you about the 'software fix' in the works is a load of crap. This is not how a TSB or a Recall works.
Have you taken it to a different dealership to get a second opinion?
9spd is made by ZF. Controls are Honda, but hardware is ZF. These guys make transmissions for many makes and models out there. Similar to the Takata airbags. Similar to the fuel injectors. Similar to the intake manifolds. Just because it has a Honda part number, does not mean that it was made by Honda. The best they can do is document the problem and work with the supplier to get a resolution to your issue.
First year models are always prone to disaster. Seen it in practically every single first year models in Honda and Acura. The '17 Ridgeline, '19 RDX, '18 Odyssey, '06 Ridgeline just the few that is relatable by some here. Word of advise, dont believe everything you hear from someone at the dealership; just because they wear something that says Honda, does not mean it is the truth.
