my old ford flex had aftermarket 20x8.5 +45off rims for summer.
i was wondering if i could use this rim on the odyssey2011 touring for summer and when i checked the FAQ sticky here, it doesnt seem like a recommended fit.
but then i went to the tirerack website and punched in honda odyssey 20" package and to my surprise , the same rim came up as a viable option for the odyssey, paired up with 245/45/20 tires....
will this package work? no weird look ? doesnt stick out? etc..
The Ford bolt pattern is a 5 x 114.3 so it will not bolt right up to your Odyssey. You can fit them with adapters that will change the bolt pattern but they will space the wheel out about 3/4"-1" further. If they will still fit under the fenders at that point then it can be done but you have to be comfortable with using the adapters to bolt the wheels on.
