Administrator
Moved to the First gen Oddy as the NZ 2000 Oddy is actually what we have as first gen oddy here in the US. :)
Search through this forum and you will find some threads about it.
You won't find much on the Awd system on here that model was never available in the U.S.
I've got the AWD 1995 ody and i haven't got a snow button any chance you could put a picture of the button on and may be some pics of the AWD gear under the car. The AWD system on the first gen ody is the same as a 1995 onwards CR-V it shifts power to the rear wheels when the front wheels spin this is done via a set of clutches in the rear differential. So most of the time the car is front wheel drive and then when they slip at a set speed the clutches engage and power is sent to the rear wheels making it AWD. Its a very simple system and a similar setup on the 1st and 2nd gen Toyota Rav4. One thing to mention the rear diff oil degrades fairly quickly so regular changes are a must and only use genuine Honda DPFS fluid or it will wreck the diff.If you drive in full lock round a car park and get a noise from the rear like a grinding or some judder from the rear then the fluid is shot. For a more in depth description of the system Google Honda CR-V AWD system :D
