The owner's Manual specifies 5W20 oil for my 2002 Odyssey. Can I use 0W20 instead?
Based on my understanding of oil weight, the answer seems to be not only yes, but also better. My logic is as follows:
1) At operating temperature (after engine warms up), there is not much difference between these two weights of oil. They both have the viscosity of a SAE weight 20 oil.
2) During start up (when engine is cold), 0W20 is thinner than 5W20, therefore has better lubricity. It reaches to bearings, piston walls, camshafts, and valve lifts faster than 5W20 does. Since most of engine's wear occurs at cold start up, 0W20 can reduce engine wear. It also may improve MPG slightly.
3) People often argue that a heavier oil generates a thicker oil film, therefore provides a better contact surface protection. But during cold start up, there is very little oil on the surfaces that need to be protected, so the first priority is to send oil there to generate the protection oil film. Because 0W20 flows faster at cold temperature, it will achieve that goal sooner. Once engine warms up, both oils behave the same (SAE 20 weight), therefore produce the same file thickness.
Then why didn't Honda specify 0W20? Was it because 5W20 was cheaper (no longer so)? Was it because 0W20 was not widely available in 2002? Or does 5W20 leave more residual oil molecules on surfaces? Did I miss anything?
I'd like to get your opinion.
