I think you covered all the potential issues except high altitude thinning of the air. ;-)Sometimes the coolant temp is not regulated by the t'stat. Once your t'stat is full open, it's up to how well your coolant mix absorbs and releases heat, ambient temperature, flow capacity of cooling system, air flow through radiator, and heat generated in engine & trans. Engineers design in a certain "reserve" cooling capacity, based on design ambient temp and engine/tranny load. And efficiency loss for use/aging. Every bug on the front of your condenser, every little crush of condenser/radiator fins, reduces the system's ability to transfer engine heat. Water would be a better heat transfer medium than EG, but we need the anti corrosion properties in coolant. Sexy hoodlines and weight reduction goals weigh against that big, thick honkin radiator.
Perhaps Ted is intimidated by your new hairstyle?Ted as always very insightful with his "smart" comments.
Unless the engine cooling capacity is overloaded, the T'stat is designed to keep the engine operating at a preset temp, and thus the oil temperature should remain nearly the same, whether a nice or hot day.My confusion is environmental temperature effect. For example, driving the same car in a nice (80F) day vs. a hot (110F) day on a freeway, given all other conditions unchanged (altitude, speed, windage, load), by how much will the oil temperature change inside an engine after warm up?
Well, everyone knows that, so it goes without saying, LOL.I think you covered all the potential issues except high altitude thinning of the air. ;-)
Sorry to hear that. Current temperature is 64F here, and will be 68F at 3:00 PM.Unless the engine cooling capacity is overloaded, the T'stat is designed to keep the engine operating at a preset temp, and thus the oil temperature should remain nearly the same, whether a nice or hot day.
But I should remind you that where I am, we now consider 40degF a "nice" day, and adding a little sunshine, we would call it a beautiful day.
I heard that both Kirkland Signature and SuperTech oils are from Warren Distribution. They probably are the same oil, with different additive formulation.The MSDS will often give the name of the "manufacturer".
Yup. True. That is why I got in on the Costco Price mistake a couple weeks back. Picked up 5 cases of the stuff. 2 of 0w20 and 3 of 5w20.I heard that both Kirkland Signature and SuperTech oils are from Warren Distribution. They probably are the same oil, with different additive formulation.
Why would you figure different additives?I heard that both Kirkland Signature and SuperTech oils are from Warren Distribution. They probably are the same oil, with different additive formulation.
No facts, just speculation.Why would you figure different additives?
Jump??????engine temps can jump to 150+F with heat soak, after a good highway or hauling drive on a 100F day.
I expect each name brand has its own formulation so the brand can advertise that it has a unique formula that makes it better. But 've not seen any oil advertising by WM or Costco, let alone claims to be superior. Not a Costco member, though, as they have no location near me. Bottom line, I see no reason for WM or Costco to want to make their product unique just for the sake of uniqueness.No facts, just speculation.
I heard that many oil distributors distinguish their brand names from others by specifying the quantities of additives with the oil manufacturers, even the oil is basically the same. Similar to fuel.
I could be wrong. No first hand evidence though.
I think you meant "can jump by 150F with heat soak".engine temps can jump to 150+F with heat soak, after a good highway or hauling drive on a 100F day.
good advice on the cool down method... likely better to leave it running on short stops, vs stop and starts.I think you meant "can jump by 150F with heat soak".
I can't speak to the amount of temperature rise, but it's significant after shutdown when coolant, oil, and air stop circulating.
I do what heavy trucks do to minimize heat soak after a hard run in hot weather - let the car slow itself without braking, drive slowly to the parking spot, idle the engine for a minute before shutdown, and raise the hood if there's no breeze.
@4vforever: Wow, that's something! My 02 is only at 146K now, and I am wondering how I can get where you are.I'm at 250,000 miles on my 2000 Odyessy and I'm thinking sooner than later, I'll just stop changing my oil and just top it up due to evaporation and bypassing the seals and rings.
Well these engines are so well built,I don't think that will ever happen.
I never have to add any oil In between oil changes.
Also, never used synthetic oil in my engine and thinking due to the high mileage I have, I don't need that extra expense.
It's your call, but I think using synthetic oil in an old engine that has been well cared for is a waste of money.
I call the van bullet proof, we paid and arm and a leg new for it and also neglected the transmission for the first 100,00 miles. Never knew we had to change the transmission oil at every 30,000 miles like I do now. First transmission was on warranty. The second rebuilt was due to my son gum booting it to the local ski hills with friends. Honda paid half for that rebuild.@4vforever: Wow, that's something! My 02 is only at 146K now, and I am wondering how I can get where you are. How do you take care of it? Any transmission issues? Do you do any oil / fuel treatment?
We're all entitled to our own opinions, but not our own facts. Walmart's Supertech oils meet all industry and manufacturer's standards, and the costs are as follows for 5 US quarts, in USD:Also, never used synthetic oil in my engine and thinking due to the high mileage I have, I don't need that extra expense.
Talking about the minuscule price difference between dino and syn in Walmart, I just did an oil change there a month ago. The dino price is < $20 (pit crew), while the full synthetic is more than double, over $40. Not sure how they determined the prices.We're all entitled to our own opinions, but not our own facts. Walmart's Supertech oils meet all industry and manufacturer's standards, and the costs are as follows for 5 US quarts, in USD:
Dino jug 13.47
Full syn jug 14.64
Full syn from 12 qt bag in box 12.45
So, what's the waste of money?
