Folks, Good series of posts on this subject of oil. Always a lively discussion!
I'll chime in from the perspective of having the opportunity to consult with several of the companies that present brand- name oil, those in the silver, yellow, blue containers...One thing to keep in mind when considering what is a fact about oil, is that the product only needs to meet the rating stamped on the bottle and the API service number. So a $34 dollar bottle of API-SN plus, 0W-20 oil, will have to meet the same minimum standards as a $17 bottle. But it is true that manufacturers may use a variety of base oils and additives to meet these minimum standards. Working with a company that manufactures a particular type of additive and selling into all the majors, I understood that different manufacturers buy different formulations, different purity specs, etc. And the actual formulation is a serious trade secret. To a certain degree, you almost certainly will get what you pay for.
On the ability to evaluate the different oils, that is pretty technical and tough to do! Without a membership to the tribology division of ASME and the related publications that may address this subject, none of us will ever have anything other than anecdotal information and our own preferences and tolerances to guide us! I stick with the silver bottle and good filters and when I parked my 2003 Ody with 310K on it due to an (original) tranny issue, that engine still cranked and ran as well as any engine I ever had (except one old Volvo 4 cylinder).
On the issue of temperature ranges, keep in mind that the car is a system and where and how we run it affects a lot of the operating parameters. I am certain the engineers designed this car to run steady-state in the vast majority of climates and conditions anticipated by minivan drivers, accounting for some accumulation of bugs ;-). If you track your data using an OBDII sensor, you will run for a long time without changing coolant temperature much. Certainly, the heat generated and transmitted into the engine oil and transmission fluid will fluctuate, but the coolant system will remove that heat as designed, and strive to keep the system at equilibrium and within specs. Higher stresses will result in higher temperatures and loads on the system, including the lubricants. That's why at least older cars had different specs for "severe service" conditions. Not sure if this 2011 Ody I have has that.
A long time ago, someone advised me that the narrower the range of the oil weights (5-20 vs 10-50) the fewer additives needed in the package. I don't think that is based on factual knowledge, as the additive package in motor oil can run up to 30% by volume, and those additives do all kinds of things, in addition to controlling viscosity.
My 2 cents, worth price charged....
