1 - 9 of 9 Posts
I have a 2006 Honda Odyssey. When I try to put it in drive it turns off the whole engine in the car stops. Does anyone know why this happens?
Two things come to mind:
  • Dirty IAC (idle air control) valve
  • Stuck torque converter lockup mechanism
How is the idle quality in P or N? What is the idle speed (when warm)? Does it also stall when shifting to R? Is the check engine light on?
Dave
You have 2 threads on this. The other one asks about the starter, stalling is not a starter issue. Get back to us on Dave's questions.
Discussion Starter #4
Dave
When its in p and n its fine but when I put it in drive it turns off or any other gear's.
Discussion Starter #5
Dave
And no the engine light isn't on.
I'm leaning towards torque converter here b/c it's fine in neutral and park
Sent from my ONEPLUS A5000 using Tapatalk
What is the idle rpm when in neutral?
You didn't state "how" it stalled - did it shut down immediately (like no spark), sputter to a stop (like a clogged fuel supply) or fairly quickly come to a stop, maybe smoothly, as if it was stopped with a brake?
I had a dirty IAC valve once. The symptom was an unstable, loping, hunting, idle speed. The engine never just "stopped". I replaced it with a "Standard Parts" brand part from the local store. Inside the Standard Parts box was an OEM Denso IAC valve.
1 - 9 of 9 Posts
