1 - 17 of 17 Posts
me too;)
Discussion Starter #5
mjody, can you post a pic ?? I want a strut bar for the Ody but I don't like the traditional, three piece bars. This one seems solid and would do a better job than a bar with bolts on top. It resembles a Neuspeed bar I had on my 96 Integra.
Discussion Starter #7
Discussion Starter #10
I ordered the Sprint bar .. I'll post when it gets here.
Discussion Starter #11
The bar arrived and I'm having a bitching time getting it installed. As far as I can see, the bar bolts on to one upper control arm bolt and one strut bolt. However, I can't seem to get it in-place. On the driver's side, the bar collides with some fuel hard-lines. On both sides, the control arm bolt doesn't easily line up. I guess I can pull it into place but, is it supposed to be this hard to get it installed ??
Does the strut bar improve handling on Odysseys with stock suspension or do you have to have other suspension upgrades to notice a difference in handling?
Thanks
jonblack
Discussion Starter #15
I forgot to post back .. I could NOT get this particular bar installed. Getting the bar past the wiper motor was a bitch and then the bolt holes would not align at all.
Huh, weird i put a no-name strut bar from a 94-97 Accord on my 95 Ody and only had to push a wire harness out of the way. The holes lined up fine.
Thanks
jonblack
So, can someone who has a strut bar installed comment on the above question?
Thank you
jonblack
1 - 17 of 17 Posts
