I own a 98 Odyssey with automatic transmission. Off late I notice that the very first time I start my van in the morning, the gears don't engage/change immediately, but engage after a slight delay and a sudden surge. After couple of gear changes the behaviour is normal. Evenings when I drive the van back from work I don't experience any surges like this. I changed the transmission fluid/filter flush, but status quo. Anyone has any insight into what could be happening?
My 95 does the exact same thing! It seems to be related to the outside temperature. It never happens in the summer and here in Tucson there are only a few days in winter cold enough to cause it. I also have changed the transmission fluid with no improvement in the situation.
It sound like your all describing shift flare.
Have any of you pulled the shift solenoids and cleaned them? I would replace the o-rings while they were off. I have seen accords with trash or just gunk build up on the solenoids and when the fluid is thick it can't flow to make the shift. I read a honda tsb about it a while back recommending you clean and or replace the shift solenoids. Might be worth a try.
true, but if you're not mechanically inclined to do so, try switching to synthetic atf. did this once, and made drastic improvements over what the p.o. condition had described. plus, synth oil last longer than standard atf. your choice.
