After replacing center door roller bracket, the door will not open with the button. Works fine with the handle. When button is pushed, door tries to open but looks like it senses overload so it faults and then latches back fully closed. Comparing to the passenger side, which I also replaced the center roller braket, the door pops open at first then rolls open. The drivers side does not pop open. Is there something in the door that causes it to pop open far enough to fully release the latch? Would calibrating the door solve it? How can I calibrate the door?
Thanks,
Thanks,
