Hello I just bought my wife a 99 Odyssey. I have been a honda lover since the day i could drive just have a couple of questions about the van... on the dash the DRL indicator is on unless i turn my lights on whith the switch then the indicator turns off can anyone explain? also my rear driver side sliding door indicator on dash does not turn on when door is open but light will light up when van does its test for dash? any help would be great thank you...
The DRL is just showing the daytime running lights are on. When the headlights are on the DRL are off so the light is out. As for the sliding door check the door open switch.
Thanks alot... So i have nothing to worry about when the indicator light is just..Its just telling me everything is working correctly
