I have a 2007 Odyssey EX. Two months ago we had problems with the A/C. We took it to the dealer where they wanted to change the compressor (estimate was $1400.00), we didn't feel there was anything wrong with the compressor and after some discussion they fixed it by replacing some valves, the relay and recharged it. It was working fine after that work was completed.
Approximate two weeks ago, the air pressure started fluctuating in the front. The back vents blow just fine, but the front starting blowing hard then soft and so forth. Now the air is pretty much non-existing in the front unless we hit a bump, then it blows out a hard puff of cold air and then it goes away. The air is cold, but it doesn't blow on either auto or by manually setting it.
Any help would be greatly appreciated on what the problem could possibly be.
Thank you.
Thank you.
