Hey everyone! If somebody could help me I’d greatly appreciate it!
I bought a used 2009 Honda Odyssey and ac wasn’t cold. Rented manifold gauges from Oreily’s, and realized there was zero pressure in the system. I pulled a vaccum and let it sit but it couldn’t hold a vaccum for more than 15 minutes without starting to lose pressure. I pulled a vaccum again and immediately loaded it up with refrigerant with uv dye (compressor kicked on right away and it started feeling cool, mostly on the passenger side) and I started looking for leaks but didn’t see anything in the engine bay/any of the lines, or the compressor, or condenser. I realized that when I first would turn on my A/c I would smell refrigerant, and I’ve read that could be a sign of a leaky evaporator core (don’t know if that’s true or not.) But either way started taking the glove box apart and I realized there was no cabin air filter at all and when I got to it the evaporator was completely covered in caked on dirt and dust, some leaves, etc... But I’m confused because I didn’t see any leaks at all with with my uv light on the outside of the evaporator or expansion valve and I know it made it there because I saw dye inside the lines going to the Evaporator.
Does anyone have any other ideas of where this leak may be? I’m thinking I should forsure replace the evaporator just because of how dirty it is. But I still don’t know where my leak is.
