1 - 2 of 2 Posts
2001 Ody A/C compressor is on, and blower is working according to temp set on climate control. Air is just not cold ( fnt/rear). Any info would be aprreciated. I know there are all kinds of relays and transistors on the HVAC. Wanted to get some info before thinking about adding refrigerant.
You will probably need to add refrigerant. DON'T use the kind with leak sealer. I did and ruined my A/C system.
The DIY cans with the small gauges are not accurate. Get a shut off valve for the can when you get the small cans of refrigerant or you will waste it when it's near full. I bought a gauge set at Harbor Frieght not the best but I'm only a DIY and they worked for me.
If you aren't sure of how to do it take it to a trusted shop. They are hard to find with reasonable cost.
1 - 2 of 2 Posts
