I will check these relays.I had the same problem with my van and it came to be both A/C and condenser fan relays were burnt. Both relays are located together next to condenser fan on drivers side.
I am parting out my wrecked 98 EX . If you could give me a picture or diagram of what you need I may be able to help you. SteveAfter replacing this relay we found a little leak on 'Suction Pipe'; this pipe is located between the evaporator and a flexible hose behind the radiator.
Part# i8032isx0a61
Value is around $160 at Brickell or at Parts.com
Do someone know if i could find one at cheaper price ?
Thanks,
Charles
