How many miles on the vehicle?
How long has it been since you changed the transmission fluid?
I found out that after starting a cold engine and before driving, if I shift from Park directly to Drive first and leave it there for a couple of seconds, and then shift into Reverse, the clunk is greatly reduced.My 2000 Ody transmission mounts sheared in half, changed them and it’s better, but still makes a bit of noise rev to drive and drive to rev. Still on my original motor mounts at 257,000 miles.
How easy or difficult was replacing transmission mounts? Any writeups or video you recommend? ThanksI agree that in colder weather, it makes more noise until the transmission warms up. Looking at the motor mounts, how does one tell if their worn out without putting the van on a hoist.
I Have a set ready to go in, but the front lower one doesn’t look worn.
The rear one is a bugger to see and the one by the power steering pump looks brand new.
They are all Honda mounts, and the ones on the shelf are knock offs/aftermarket.
Super easy, take off the front drivers tireHow easy or difficult was replacing transmission mounts? Any writeups or video you recommend? Thanks
