I've searched the forums and not found my exact problem, so I appologize in advance...
I blew the passenger #9 fuse (ACC) in my 2004 Odyssey...too many ipods and DVD players, I guess. When I replaced the fuse and restarted the car, the ABS, TCS and BRAKE warning lamps are lit and will not go out.
Brakes work normally, although I cannot tell if the ABS and TCS are working.
I plugged in my scanner and it gives me - - - - no error codes.
I have checked all other fuses and none are blown.
Any other thoughts on this one? Could my brake controller be hosed? Should I attempt the light reset procedure, risking that there is really something wrong?
Thanks in advance.....
