Our front AC blower motor went out during a long trip. I ordered a replacement blower and resistor since I had to get in there anyway. Took about an hour to swap out the parts and I noticed a lot of moisture on the old blower.
It worked again but made this odd bogging sound whenever we made a left turn.
After some research, I determined that the condenser drain was clogged. I blasted it with compressed air and it splurted like a garden hose. Problem solved. You must use air, the drain has a 90 degree angle so a wire will not work.
The drain hose is on the driver's side, aligned with the rear of the front tire. You must jack up the van to access it. You can see the water coming out in the pic. I am posting because I looked everywhere online and nobody has described the location of this darn hose
Automotive lighting Bumper Font Gas Space
2016 Touring Elite
A long zip tie or trimmer string can work too (for sunroof drains too). Metal wire can damage things in the pipes/hoses.
-Charlie
Reactions: Gumtape
