1 - 6 of 6 Posts
All,
Need some help here. AC worked fine yesterday and today i pushed the AC button and nothing. Compressor does not engage nor does the blower work inside the van either. The blower only works when i turn it all the way to max.
The rear fan blower works fine. I checked the fuse #3 according to manual, on the drivers side and it did not look blown.
My guess is if the blower does not work and the ac clutch does not engage then it must be a fuse somewhere. Any tips?
It is a EX model, transistor pack?
Can you get it local auto parts stores and will this cure my AC compressor not engaging? It only engages for about 2sec when the engine starts then cuts off.
I don't believe you'll find the transistor assembly at an auto parts store. The OEM P/N is 79330-S84-A41 for my 2004 EX, cost was $52.83 a few years ago at my local Honda dealer; you can buy one on-line for less.
New one on the right.
Located on the passenger's side under the dash near the blower. It's secured with three screws.
Thank you for great pictures. It will help when I install it.
Actually found it at Advance Auto parts for $41.99.
BWD/Intermotor Blower Motor Resistor
Part No. RU828
$41.99
1 - 6 of 6 Posts
