21 - 40 of 80 Posts
Discussion starter · #22 · (Edited)
Thanks for posting that. Is that the entire procedure or is it continued on the next page? If it's continued, can you post the rest of it? I wonder if, for some reason, they purposely left that whole section out of the 2007-2009 manual or if it was an accident. I don't even have that section. I have the section I posted above that covers "both" the radiator fan and the condenser fan high speed circuit.
I am still trying to figure out what caused the fuse to blow. Is the motor failing and just drawing too much current intermittently? I couldn't find any wiring problems anywhere. I don't have an amp clamp to check the current draw to that motor. I might be able to use my meter to read the amp draw across the load side relay terminals to check current draw on the motor. A wearing motor will draw higher than normal current. Or maybe there is an intermittent fault in the underhood fuse box.
I also wonder how many other vehicles have this problem and people don't even realize it. There is no real symptom that is very noticeable. I just happened to notice on a couple of occasions where I actually drove the van (my wife drives it most of the time) that the AC got a bit warmer than it should at idle, but my wife never noticed and never said anything. You had the same problem and didn't notice a problem either. When I put AC gauges on the car (because I actually thought I had a refrigerant charge issue at first) the high pressure side was going up to 350psi. The fans are supposed to kick on high at 221psi and bring the pressure down. 350psi is way too high and can damage the system if it isn't addressed. I can only wonder how many compressors are failing due to this issue, especially when combined with the very common stuck relay problem.
Discussion starter · #24 ·
Wow. That's a completely different Symptom Troubleshooting chart than in my manual. The same problem in the 2007-2009 manual says to go to the Radiator AND Condenser fan high speed circuit troubleshooter. Very strange.
Just to make sure we're on the same page on this, the radiator fan is on the driver side and the condenser fan is on the passenger side. If you look at the wiring diagram, the condenser fan is never powered by the radiator fan fuse (#11.) So, that means a failing condenser fan will not affect the radiator fan fuse #11. On the other hand, BOTH fans are run in low speed mode by the condenser fan fuse #9 so a failing radiator fan could blow the condenser fan fuse #9 and/or fuse #11. If your condenser fan was shredding itself it might blow it's own fuse #9 but wouldn't blow fuse #11.
The only thing that can cause fuse #11 to blow is a short to ground between the radiator fan and fuse #11. The fan control relay (a 5 pin relay down under the power steering pump reservoir) is tied into that side of the circuit too. But, even if the fan control relay were to stick and not move into the high speed position when the radiator fan did, if the condenser fan were shorting out internally it would only short power from the radiator fan to power on the condenser fan. There would be no short to ground to blow the fuse. Now, if the fan control relay was failed and somehow making contact in both of it's positions at the same time you could have a short to ground in that fan control relay. I don't think the condenser fan failure itself caused your fuse #11 to blow. You could possibly also have a problem in the fan control relay. I could see the fan control relay possibly being damaged if the condenser fan were drawing high amps or shorting out internally. The condenser fan could take out the fan control relay. It could also take out the condenser fan relay, too.
The condenser fan is the passenger side one per the manual. You are correct the bad condenser fan could not have blown fuse 11, so I have no idea what and for how long ago it's been blown. I've just replaced both fan relays about a month ago (just to be safe, the old ones tested fine) I should have checked the fuse 9 & 11 too, shame on me.
Discussion starter · #26 ·
I also changed both fan relays about 3-4 months ago but not for any reason other than they were the same relay that often fails for the AC clutch. I figured they were old and I bought 5 of them on eBay for cheap so I just replaced all three of them. I have no idea if the fans were working properly then or not.
There is also a 5 pin fan control relay down under the power steering reservoir and that's the one that could possibly take out the radiator fan fuse if it somehow were to short internally. It's a different relay than the others so I haven't replaced mine either.
Discussion starter · #27 ·
Update:
I was looking this circuit over again and just realized that for the troubleshooting procedures I was in the AC chapter. The AC chapter covers radiator and condenser fan issues but not radiator fan issues alone. For that I needed to be in the Engine Cooling chapter where the proper procedure (as posted above) is located. Had I found that initially it would have taken me to the #11 fuse right off the bat and I wouldn't have spent two hours chasing the whole thing down and suspecting my PCM for a while.
In my defense, though, the only time I had a problem with the circuit was when the AC was on. The condenser fan ran on high but the radiator fan shut off. Under normal engine cooling operations both my fans were working normally on low so it was an AC problem. It's definitely poorly organized in the service manual.
Also Check For:
Blown fuse No. 11, 30A in underhood fusebox
Radiator Fan Relay stuck openy.
Hey guys, sorry to revive this thread but I have an addition to this 'Also Check For': Verify that A/C Diode B (sometimes written as "Radiator Fan Diode") is - get ready for it - INSTALLED!!!!. Somewhere along the line I had removed and not completely reinserted the diode so I was getting John Clark's exact symptoms on my 2006 Odyssey, low speed both were on, high speed radiator fan stopped. If you are not familiar with where this diode is (this is not the one in the under hood fuse/relay box - that is A/C Diode A) lay on your back, look at the brake pedal, then look straight up under the dash, it may be taped to the wire bundle, mine was just hanging there (yellow/red in and yellow out).
Discussion starter · #31 ·
It's funny you bumped this today. I just had a 2007 Odyssey in my shop today for a blend door motor issue and check engine light. I noticed it had an inop radiator fan when fans were on high. Went right to the 30A fuse and found it blown. 30 seconds later I had it fixed. I asked the owner if they noticed warm AC at stop lights or idle and he said they had. He was pretty happy! Probably gained a good repeat customer.
Great thread John, I was noticing my ac was not so great today in my 08. Actually it has been that way for a while. It also seemed that high speed fan operation was excessive. I checked the AC pressures and they seemed ok. Then I did notice my that only the passenger side fan was running on high and driver side was off. On start up they both ran at low speed.
In the morning i'll be checking fusses. I think i have the same issue.
Great tip Thanks
Couldn't wait for morning. 2:00am under the hood and sure enough #11 blown!
Reactions: Drod@492
Discussion starter · #35 ·
Glad it helped. I've found the same fuse blown in other Odys since starting this thread. I'm not sure what causes it. I've checked the current draw on the fan and it seems fine. Since changing mine it hasn't blown again and it's been 21k miles since I found the blown fuse. Keep an eye on it, though, and if it blows again I'd replace the fan motor.
So I am having similar issues with my 08 Odyssey. At stoplights, AC get warm. If I start the van with the AC on, it never gets cold until I start moving. I've checked all relays = good. Fuses = good. Diodes = good. Both fans come on at low speed but I can never seem to get them to come on high speed. I've checked AC pressures with a gauge set, but have not actually vacuumed it down and made sure it had the proper amount of Freon in it. Dreading having to replace the PCM fro an AC problem.
Discussion starter · #37 ·
It's important to know what turns the fans on to high speed. Take a look at the wiring diagram I posted initially. When you turn on the AC the pressure in the high side should start to climb. When it reaches 221psi the fans should turn on to high speed. What kind of pressures are you seeing on the high side gauge? If you're not getting 221 psi then you either have low refrigerant or a worn out compressor. Your low side reading should be around 25-35psi. If you're getting 221psi on your high side gauge and both fans are staying on low then it sounds like it could be a pressure switch issue. The first thing I'd do in your case is to jump the high speed pressure switch wires, to simulate 221psi, and see if the fans turn on to high. It's the black wire and the brown and white wire. You can also just use a test light with the clip connected to ground and touch the brown/white wire.
Glad to see this post revived, I'm currently experiencing similar symptoms as KayDub. The wife occasionally complained about the AC in stop and go traffic, but it wasn't until we spent time in very hot Las Vegas this week did I see it. I actually started over heating in stop and go driving, but fine at freeway speeds. It seems the Radiator fan is not coming on at 220 degrees. Like KayDub, fuses are good, fan powers on low with the AC on. I'm leaning towards the Radiator Fan Switch/Thermo-switch. I was curious that that never came up on the previous case that John described. In any case, there looks to be two of these, one switches the Radiator fan on, the other tells the Computer what the temp is. Anybody with the manual able to tell me which one is the radiator fan switch? Thanks to the OP for a great write up. Maybe my experience will add to it.
Discussion starter · #40 ·
There is no "radiator fan switch/thermo-switch." The radiator fan is controlled by the PCM which gets its inputs from the coolant temp sensors. They both perform multiple functions and don't only control the radiator fans. You'd need a scan tool to determine if the coolant temp sensors are working properly.
21 - 40 of 80 Posts
