I am having some issues with my AC in the 2003. For some reason when you start the van up, the AC in the dash wont blow. None of the settings get it to turn on. I can rotate the dial from auto to make the fan blow high and I can hear it clicking but it wont turn on.
If you hit the dash a couple of times right above the clock, then the fan starts blowing but its hot air. If you turn the car off and back on sometimes it will come back on and blow cold. When its working it blows really cold. One weird thing I noticed. My rear windows wont pop out when the AC dash fan does not come on. But when you bang on it and the fan comes on, then the rear windows go in and out. I dont know if its related, but its very strange.
Any ideas? I thought maybe the Transistor assembly, but its to far away from the dash where I rap on it and the fan turns on. The rear fan always works but if the front dash fans do not turn on it just blows hot air. Once the dash fans come on with cold air then everything seems to work just fine.
Should I replace the Transistor assembly since its fairly cheap just to see if its related?
