I might have to replace the rear wheel bearings. Should I go OEM or aftermarket and any reccomendations. Do I have to get the entire assembly or just a bearing. Local dealer says only comes in the assembly, about $200.00 each. OUCH!!!!!
I'm not sure which year Odyssey you're referencing, but on a 2001 model, you replace the entire hub. It's a relatively easy fix. Rockauto.com has several aftermarket options from reputable manufacturers in the $70-100 range. A search here should net you multiple threads on how to fix this issue.
I don't see a reason to go OEM Honda on the rear wheel bearings. A good quality aftermarket should suffice.
