Are you looking to just unlock the doors, or start the car too? I am guessing that unlocking the doors would be easier to retro-fit.
Unlocking doors is most important to me, but I will take both, but like I said, unlocking doors without pulling out the key is most important. Any ideas?Are you looking to just unlock the doors, or start the car too? I am guessing that unlocking the doors would be easier to retro-fit.
Always got a better fit with our car seats using the LATCH system versus seat belts. And always able to install and uninstall for clean up quicker and easier. It's really my husband's preference.Although I am not familiar with any of the aftermarket systems, I think that it might just be easier to look into the seating configurations of the Sienna or Quest. It seems as though it would need to be very integrated to give a useful and secure method operation. If you really want to try and look into this, I would suggest you look into salvaging a system used in a late model Acura. I think it would still be a rather complicated job, but I know a lot of the equipment is shared.
Since I don't have kids, you will have to forgive me for asking this next question since I know everyone else here is probably very familiar, but here it goes. What is the benefit of the LATCH system? I know how it works and I have read about it, but from what I have found, it is supposed to be easier to install than traditional seats, but not necessarily safer. I have installed both kinds of seats in my van a couple of times and from what I can tell, the LATCH system was way harder. So unless it is safer, I don't see the benefit.
This is incorrect. LATCH does not create a safer install. The LATCH system is not safer than seatbelts. Many LATCH systems have weight limits that need to be considered. Also, remember that hen using a forward facing seat you must always tether it when using LATCH. Otherwise the seat is not being used correctly.Latch system allows for a much more secure and tighter fit for the car seats and seat bases. When using the seat Belts I can never get it to be as secure as the latch. It's a much safer way to instal car seats
Agreed. Latch usually has a max limit of around 50 pounds where as the seatbelt doesn't (within reason).This is incorrect. LATCH does not create a safer install. The LATCH system is not safer than seatbelts. Many LATCH systems have weight limits that need to be considered. Also, remember that hen using a forward facing seat you must always tether it when using LATCH. Otherwise the seat is not being used correctly.
I am a car seat tech and I use seatbelts on most of my installs. I can I install just as well with seatbelt or LATCH.
Yes, Latch can make it more convenient or easier to install vs a seat belt. But it's not any safer than the seatbelt. Latch ends around 50 pounds or so. Latch car seats can be installed improperly as well.I think it would be too integrated to be put in easily. I'd prolly look into a Sienna. The Quest doesn't seem to have families with small children in mind.
I know it's more convenient, but is it that much more? I don't find that it is. It's helpful if I forget to look for the keys at the last minute, but I still need to set down a car seat or let go of a toddler's hand (and risk them running off). I have keyless on my Lexus. I don't find it that much more convenient than remembering to grab the keys and stick a finger through a key ring. Either way, I got free up a hand to grab the door handle to open. At that point, not a big deal to hit the button on the remote. At least with the Honda remote, if you do it this way, you can remotely open the side doors (if you have an EX or above). The main problem of having to set down a car seat or let go of a toddler's hand is still there.
What would really be helpful is the keyless option connected to a sensor at the bottom of the car. They have this currently on some cars, but only for the trunk/rear hatch. You wave your foot under the bumper, and it opens the trunk for you. They should add this to the sides of the car and open at least the rear sliding doors if you wave your foot under the car.
And LATCH can be a lot more convenient and/or easier to use than a seat belt. Depends on the seat of course, but in general, it's easier to use properly. That's the key. Prolly 90% of parents install the car seat wrong. If it's installed improperly, the safety benefits disappear. Anything that makes it easier to install a seat properly means that many more kids will be better protected. Nice to have more good options. Particularly in a center seat position where the roof mounted belt can be awkward and cause sightline issues.
