If the center bore of the wheels is larger than 64.1mm, plastic and aluminum Hubcentric adaptors are readily available online. If everything else is compatible (overall diameter, offset & lug type) they could bolt right up.
www.uswheeladapters.com
Hub Centric Wheel Adapters
Hub Centric Wheel AdaptersWe precision build hub centric wheel adapters to fit tight to the hub of the vehicle and offer a lip to pilot wheels perfectly.
