99 ex 130k. (much loved). A/C has quit cooling. Tried recharging freon, and it was a bit low, but now is good. Attached gauges to hi and low sides and both show same pressure, about 60psi. The compressor is running, and i can switch the clutch on and off by pulling the fuse, and when it engages the engine slows slightly under load, which is nice. However, none of the pipes get cool, which is not nice. My question is please, it SEEMS like the compressor is bad, but before i spend the $400+ on parts, anything else that could cause there to be no high pressure? The system is not leaking. thanks much. very much.
