1 - 2 of 2 Posts
05 Odyssey EX-L I had the silver plastic piece off under the stereo system in the dash. I unplugged the airbag connection to remove it and turned the key to the on position to check the stereo out, when I did this it caused the airbag light (red in color) to stay on now. How do I reset it? There should be a MES connector or some way to reset it without the dealer needing to do it.
The airbag system checks to see if this light is operational as part of it's diagnostics. You unplugged the passenger airbag light when you removed the silver trim which caused the car to think that bulb is burnt out. This happened to me too.
Once you plug the passenger airbag light back during your re-install of the trim and the next time you start your car, that light should disappear. No need to visit the dealer for this.
1 - 2 of 2 Posts
