Well I finally got it put in and I can enjoy my old tapes and new DVD's now. About a 2 hour job with lots of water breaks. I mounted the VCR under the 2nd row seat behind the driver-4-screws. Then I ran the power wires and remote "eye" wires under the bezels where the seat mounts to to floor, under the carpet, rear and front door trim and into the fuse panel with Chuck's Add a Fuse idea (Thanks Chuck
0. I mounted the remote "eye" right in the little hole where the hood release is-very clean and nothing is visible to the naked eye. Wife can now operate the VCR easily from the driver's seat. As far as the Audio and Video wires-ran those under the bezel, under the rear door trim and then up into the input jacks. I eventually will pop the rear panel and tie the wires in beneath the panel so I can still use the jacks on top, but I've gotta get the courage up to pop the rear panel. Ill post pics and soon as I can. For what it is worth-figured out the Auxilliary jacks are only backlit when the power to the reat system is on and are not controlled by the headlights.
