I modified my '04 Ody so that the power windows are always operable i.e. you don't need the key. This, at least, makes it so that at the end of the day I can close things up without going back in the house to get the key. According to the Electrical Troubleshooting Manual (ETM) this should work the same on 99-04 models.
Essentially what I did was to put a jumper across the Power Window Relay normally-open contact pins. This lets the windows operate normally in every way, except you don't need a key.
Attached is a partial schematic from p120-5 of the ETM showing the relay. The little curved line I've drawn indicates the added jumper. Note that the pin numbers on the ETM are incorrect. The pins that get the jumper are numbered 3 & 5 on the relay.
More details in the accompanying posts.
This thread is provided only as information as to what I did, not as a recommendation for others to do likewise. Any consequences, direct or indirect, are at your own risk.
Regards,
Don
CA
Regards,
Don
CA
