first of all i have done my research but i still need some clarification from others than have experienced the problem.
my 99 ody passenger door will not open with the button, you have to pull the handle and hold it for just a second or so and it will open, you dont have to pull hard or tug on it, it will open normally as long as you hold the inside or outside handle out for just a second or two. however it will close and latch with the button just fine. Is the actuator going bad? or could it be worn linkage? i would like to know what to look for before i tear in to it.
Any help is appreciated. thanks
