1 - 2 of 2 Posts
Hello All
I need to change my 3rd and 4th pressure switches for the transmission. I have a 2004 Odyssey EX-L which is showing a code for the 4th. The part numbers have been superseded by new ones.
I just bought these and was wondering if anyone can suggest if they look genuine. Most 3rd gear switches I see are beige / tan in color but these are green. I wonder if that is because of being the old part or if they are not OEM.
thanx
Per FSM there is no test for those pressure switches. All you can do is install the new one and see if it fixes your codes/issues. You should also change your atf fluid (drain and fill) several times if you have not done yet.
1 - 2 of 2 Posts
