When you put the lights on AUTO (the stick with auto, off, on etc). The lights are supposed turned on when the outside is dark. The lights on mine were not on no matter how dark. Anyone has similar issue? You can customize the sensitivity with touring modes. The default setting on EX-L should work. Right?
Hmm. Maybe the sensor is messed up? I would just take it in. That's what the warranty is for. But that's if you have time to take it in.. But it is supposed to work the way you've described though. When the sensor senses that it's environment is dark enough, the lights should turn on.
Mine is the other way, if it is overcast, like the we always have :(, and I pass through under a building shadow, the light would turn on, this is day time.
Some time it turn on even there is cloud when previously was sunny.
I have brought it to dealer, and they said there is no adjustment for this. I have EX-L RES.
