1 - 2 of 2 Posts
Backup camera comes on under normal conditions. Put in reverse, it comes on, take out of reverse, turns off.
Now the weird part. If the ignition is on (engine running, or not) and I either press on the brake, or turn on the parking/head lights, the backup camera will turn on. This just started happening.
Also, when I press on the brake, the....button lighting on the radio...(not sure exactly what that's called) also comes on.
2007 EX with Navi/DVD/XM
Any ideas?
Ron
Look in the area of the brake pedal linkages for a pinched or chafing wiring harness. Have somebody pump the brake while you're under there so you can look for movement, or use a video camera.
1 - 2 of 2 Posts
