I bought an 2006 Odyssey Touring. There's a problem with a lot of bass and vibration at a stop while in drive, and when cruising along the highway, the vibration will kick in randomly.
I believe the vibration at highways speeds might be related to the VCM, because there is a lot of coincidence between the vibration and the "ECO" light coming on and going off, but it's not exact, there's often a two or three second difference in the timing. Also the vibration is pretty noticeable at stop lights, and the ECO light does not come on at a stop.
I took it to the local mechanic, and he said the rear engine mount was shot, so he replaced it. It made no difference. So after reading this forum, my thought was that maybe it was the active front mounts. So I took it back and had all the mounts replaced on the engine and transmission. I don't think it helped reduce the bassy engione noise or vibration really at all.
The mechanic says he has inspected the exhaust and everything he can think of, but can't find the cause. Any thoughts? Could it be the transmission itself? I don't sense that it's missing shifts or slipping, but the Odyssey transmissions have always been a little herky jerky, even on a good day.
