1 - 8 of 8 Posts
2003 Odyssey
I may have told the entire story in the thread title :)
Searched and searched and can't find which fuse controls these items:
* SRS light
* intermittent wipers
* front wiper sprayer
* rear wiper motor
* rear wiper sprayer
I'm really thinking it's a single fuse since it all happened simultaneously.
thanks a lot!! :coolio:
Front wiper Driver under dash 9, 11, 12
Rear wiper Driver under dash 11
Washer motors as above
SRS light may have to be reset by dealer. You could try disconnecting the battery, Touch cables together for a minute and then reconnect. I don't think this will work for the SRS light though. OBDII reset won't reset either. It may go out itself after a few drive cycles.
all three turned out to be fine (tested with ohmmeter - thanks for the tip).
I'm thinking its time for a replacement motor
Could it be anything else like a switch or relay?
thanks again, I really appreciate the help!
Discussion Starter · #8 ·
Aha, got it!
<-- never noticed there are 2 fuse boxes!
I was checking on the passenger side fuses, when the driver's side #11 was toast (as you guys pointed out)
replaced it, and it fixed everything: SRS light, front washer, intermittent wipers, and rear wiper. Unbelievable.
thanks again for the help!
1 - 8 of 8 Posts
