Hey gang, hoping to get some of your thoughts on this problem I'm now having.
I have a 2010 Odyssey, bought it a couple of years ago. Never had any issue with battery, charge, etc. A few weeks back, we all got covid, we (all fam) had to go to hospital. When we came back, I didn't notice the light above one of the passenger seats (baby seat) was left on.
So quarantine whatever 5 days not going anywhere, I go to start the car, nada. Dead as can be, not one light anywhere in the car. Put on my trickle charger, no go. Borrowed a jump starter battery and ran the engine for a while higher rev 2,000, to charge the battery enough, then put on my trickle charger and left it on for 12-14 hours.
Everything great the day after it showed fully charged. Even did a road trip 40min highway speed. So at this point I'm feeling good about the battery being back to "normal".
Two days later, wife takes the car for some errands, calls me tells me as she was parking all the lights went crazy on the dashboard, and then would not start back up (later she told me on the way to the parking lot the battery light also came on). This was early afternoon.
Went in the late evening to the car with the jumpstarter, but car started and didn't need it. HOWEVER
1) I am now hearing a higher pitched sound from alternator, not like belt sqealing, but kind of high pitched sound I never noticed before.
2) Battery light was on - ALTHOUGH with the OBD2 via Torque app I'm seeing between 13.5-14.1 voltage on battery.
Made it home.
Put on trickle charger again overnight, went to 100%. Removed trickle charger. Battery measured at 12.6V.
A day later (today) tried to start the car, nada. Battery voltage 10.6V (car unused since charged battery)
Checked lights inside one, nothing. Parasitic drain, I'm seeing 24mA, when I remove Fuse15 under the good, goes to 2mA; plop the fuse back in, high 1.3A draw, then goes down to 24mA. Seems anything under 30mA is ok.
Not sure what to check now, I don't know how my battery got to 10.6V from 12.6V over 24hrs. I don't think the 24mA drain would do it. Did having my battery totally drained kill it?
Additionally, when I started the car and checked voltage on battery, I see that the alternator is not providing solid 14.xV, but instead jumping all over from 13.4+ to 14.3ish, sometime just goes back to 12.5/6V...
Thoughts? Sorry long post folks.
Thanks
Made it home.
The battery was replaced in 2016, it's 24Group 650CCA>I saw a video calling out the ELD (Electronic Load Detector) replacement as it was having the same symptom while alternator charging - voltage all over the place..
Thanks
