1 - 11 of 11 Posts
Is there any aftermarket kit that offers mounting in the back of Odyssey instead of on the roof rack ? I think I saw a Toyota van with bike in the back before.
Honda makes one. Check any of the normal places for prices, e.g. hondapartsforyou.com, handa, etc.
If you look at the installation instructions you'll find that it's a pretty simple product. Assuming that you can find a front wheel skewer (I'm sure these are readily available) you should be able to fabricate your own for a couple of bucks.
Mel
<font face="Verdana, Arial" size="2">Originally posted by TurboRT:
Is there any aftermarket kit that offers mounting in the back of Odyssey instead of on the roof rack ? I think I saw a Toyota van with bike in the back before.</font>
Are you reffering to a mount inside the van ?
I have a Saris bike mount in the rear which I installed myself. Paid $19 at www.nashbar.com
Apparently Honda wants to charge an arm and a leg for this part.As for the front wheel, I just lay it flat on the floor,don't really need a mount for that since it'll get in the way when hauling other cargo.
-ROB-
'01 GG LX "Lagreat"(with stuff,just S-T-U-F-F)
http://community.webshots.com/album/18601743AkjQIJiKqK
Discussion Starter #4
I am really looking for something attached behind the tail gate. Any input/suggestions are appreciated.
Turbort, I have only seen bike racks that fit an existing trailer hitch. They are generally good and keep the bikes away from the tail gate. I don't know of any racks that strap to the tailgate. If it were me I'd be safe and install a proper swing out hitch mounted rack.
Discussion Starter #6
Canodyssey,
You are right. I think that is what I saw on a Toyota van. Any recomendation for the hitch mounted kit ?
You might want to check out hiddenhitch.com. They have some nice racks. I do not presently have a bike rack so I can't give any first hand experience at the moment.
Is a bike some sort of fuel saving device??
Jerry O.
2001 Odyssey GG LX
[/B][/QUOTE]
Do you have a part number or a specific part name that can be found on Nash's website?
$19.00..I'm *real* interested.
<font face="Verdana, Arial" size="2">Originally posted by Grantbo:
$19.00..I'm *real* interested.[/B][/QUOTE]
Ok, to answer my own question, I did a little search of the good ole Net. I found a "Traps Front Fork Mount" that would appear to work perfectly in the rear of the Ody.
I believe this is what Rob reviously referred to. Two of these mounts can be secured to a 4ft 1x6 in a staggered side-by-side fashion, to make a completely removable interior bike rack. With my two bikes stored upright, there should be plenty of room for my daughters "tag-a-long" bike.
Check it out: www.lickbike.com/i4042350.htm
Grant
'02 SS Ody Ex
'92 Prelude Si
Grantbo,
The Traps mount is also a good deal.If you are carrying 2 or more bikes, staggering is definitely a good idea.I've fit 3 adult sized bikes side-by-side and still had space for another 1.And this is with the 2nd row still up!
I actually mounted it permanently to the floor. I had to peel off the carpet, the the bottom cushion of the 3rd row. The I bolted it down to the bare metal.Used threadlock just to be sure. The bikes kinda move from side to side even with the fork mount so what I do is use a ratchet strap to hold down the rear (attatch the hooks to the 3rd row mounting hooks on each side of the van).
-ROB-
1 - 11 of 11 Posts
