Do any of you guys know what is the bolt pattern for the 2001 Ody? Looking for rims that fit....
R Ryan · Registered Joined May 21, 2001 · 27 Posts Discussion Starter • #1 • May 22, 2001 Do any of you guys know what is the bolt pattern for the 2001 Ody? Looking for rims that fit....
N nemogira · Moderator Joined Feb 9, 2001 · 1,484 Posts #2 • May 22, 2001 Inches: 5 x 4.50 Millimeters: 5 x 114.3 If you're planning to lower it...you must know offset before hand. What kind of rims are looking for? (i.e. size, brand, etc.) -nemogira
N nemogira · Moderator Joined Feb 9, 2001 · 1,484 Posts #3 • May 22, 2001 Oops. Please ignore. [This message has been edited by nemogira (edited 05-22-2001).]
R Ryan · Registered Joined May 21, 2001 · 27 Posts Discussion Starter • #4 • May 22, 2001 uhhhh offset???
N nemogira · Moderator Joined Feb 9, 2001 · 1,484 Posts #5 • May 22, 2001 Kind of hard to explain. It helps determine how are far (or not) the wheels stick out from the fender. Check out http://www.tirerack.com/wheels/tech/wheeltech.htm for more info on offset and other things you should know. -nemogira
