1 - 2 of 2 Posts
We just purchased the BOYO A-Pass Touch Keyless Door Lock from VisionTech America. We were hoping to install it ourselves but the instructions are somewhat lacking. We've searched the internet for any videos or pictures with no success. If anyone can help, it would be greatly appreciated. We found what we think is a wiring diagram for our 2008 Honda Odyssey but we don't know where to find the wires or how to connect them. We have contacted a few stereo installation stores and so far none of them have any experience installing this.
The Installation Manual says:
A-PASS Touch Wire Install:
**Caution: Main power should be connect at Key box not Fuse box
**Caution: If you can not find the "Factory Alarm Rearm output" and "Factory Alarm Disarm output" connect the Black, Red, Brown and Orange color wire only. (Factory Alarm rearm, disarm function is not available)
PinColorDescription
1Black(-) System Ground Input
2Red(+12V) System Power Input (at Key Box)
3Brown(-) Unlock Output
4Orange(-) Lock Output
5Blue(-) Factory Alarm Rearm Output (Special Vehicle Only)
6White(-) Factory Alarm Disarm Output (Special Vehicle Only)
Black: (-) System Ground Input
This wire should be connected to a ground source. Please ensure that no paint or rust exists on the surface where the wire will be attached. Also, ensure that no paint or rust exists on the surface where the wire will be attached. Also, ensure that the wire is securely fastened to the ground source.
Red: (+12V) System Power Input
This wire should be connected to a constant +12V (at Key box not Fuse Box)
Brown: (-) Unlock Output
This wire provides a negative (-) pulse to lock the vehicle's doors. This wire can also be used to control the Arm Trigger of some aftermarket security products. Please refer to the Installer Programmable Options for programming details.
Orange: (-) Lock Output
This wire provides a negative (-) pulse to unlock the vehicle's doors. This wire can also be used to control the Disarm Trigger of some aftermarket security products. Please refer to the Installer Programmable Options for programming details.
Blue: (-) Factory Alarm Rearm Output (Special Vehicle Only)
This wire provides a negative (-) pulse to rearm the vehicle's factory alarm after the lock pulse has occurred on the module. The pulse duration is 0.8 second.
White: (-) Factory Alarm Disarm Output (Special Vehicle Only)
This wire provides a negative (-) pulse to disarm the vehicle's factory alarm before the unlock pulse has occurred on the module. The pulse duration is 0.8 second.
Thank you in advance for ANY help you can provide!
PinColorDescription
1 Connect to any metal portion under the vehicle dash as it will be ground.
2 Connect to white wire locatedat IGNITION SWITCH HARNESS/DRIVER KICK panel
3 Connect to the green wire found in PASSENGER KICK panel PIN 6 OF 30 PIN CONN
4 Connect to the pink wire with black stripe found in PASSENGER KICK panel PIN 20 OF 30 PIN CONN
5 Not used
6 Not used
Hope this helps ya.
1 - 2 of 2 Posts
