2003 Odyssey EXL.
My brake pedal does not go Up all the way when i let go the pedal which makes my car to brake just a little and slow the car, so i have to use my left leg to help the pedal to go Up all the way.
New brake pads, the Brake fluid is Normal level.
Brake switch is good.
Please help any one, it's hard to drive like this.
This is obiously a dangerous situation and needs attention ASAP.
Have the brake system checked out. Could be a leak, a faulty brake master cylinder or faulty brake booster. I do not believe that the brake pedal has a return spring and operates on the brake fluid pressure.
Did you do any of the brake work yourself?
