1 - 2 of 2 Posts
Hi
My odyssey 2001 having 173000km makes a screeching noise while I brake as soon as I started. after a minute the noise goes away and drives normal. I bought the vehicle used at 110000km. If I were to buy the brake pads in USA and get it changed there for the Canadian model will it be ok.
Should I need to check anything else.
Thanks
I think the pads are the same for US and CDA models. To be sure, compare the part # online at CollegeHillsHonda.com with the one provided by your local dealer.
If the pads are worn down to the backing plates, your rotors may also need resurfacing or replacement. You should get a complete wheels-off brake inspection to determine the work that's needed. Has the brake fluid been changed per the schedule (3 years)?
1 - 2 of 2 Posts
