My 2003 Odyssey EX AC and fan stopped working except when the fan speed was turned to max. After researching these forums I found that it was likely a bad blower motor transistor. I replaced the transistor tonight and now the AC and fan work when set to speeds other than max, but the fan will not shut off even when the climate system is turned to off.
The fan seems to operate at only the higher speeds, though it will adjust slightly as the temp control is moved up and down. The mixer valve seems to be working correctly and the air temp will change appropriately based on the set point. All this relates to the front fan. The rear units seems to be working correctly.
Any thoughts on why the fan only seems to run near max speed regardless of the setting, even when the system is turned off?
