Cabin Filter Replacement/Excerpt with bulb details for Clock Light Replacement
147349 Views 117 Replies 72 Participants Last post by  kernel
As a supplement to the two very long threads on Cabin Filter Replacement and Clock Light Replacement (I posted there, too) in an effort to ease in locating and after conferring with a moderator, I am posting links to
1. A complete set of photos with caption instructions for the cabin filter replacement at:
http://picasaweb.google.com/ThomasJacobs/HondaOdysseyCabinAirFilterReplacement19992004
also found on page 15 of the thread:
http://www.odyclub.com/forums/showthread.php?s=&threadid=17078
by sueandroy entitled Cabin filter replacement
2. An excerpt of photos detailing just the actual bulb replacement process (not dash removal, etc.) for those buying the radio shack bulbs in replacing the Ody Clock light (should read 1999-2004):
http://picasaweb.google.com/ThomasJacobs/HondaOdysseyClockLightBulbReplacement20022004
which is also found on page 10 of the thread:
http://www.odyclub.com/forums/showthread.php?s=&threadid=23429
by VT FIJI Graphix entitled DIY Clock Light Replacement (with pics!)
1 - 20 of 118 Posts
help
is this cabin filter replacement sheet good for the model year 1999
iam having some trouble getting started thoes screws are hard to get to iam assuming the ones that face the bottom in other words the ones that are upside down right.
Yes it should be the same for models 1999-2004. I don't understand your second question.
Would an excessive "breathy" type noise when a/c on be a sign that this should be replaced?
Hard to say. I can tell you mine was filthy after 2.5 years so it might be worth replacing to see.
just replaced mine today - 2003 EX & 68k mi. Needless to say it was way overdue, and pretty disgusting. Thanks to this forum for the help on the change. Pretty simple job. One note - the guides above all reference 7mm bolt on the brace to drop down - mine had 8mm.
Thanks Thomas. Ive been driving around without a clock light ever since I bought it used years ago. Ive been aggravated all this time thinking how stupid honda was for designing a clock without a light and now I find out the lights been in there the whole time its just not been working.
How do I remove the dash cover to replace the bulb?
See less See more
01LoadedEx,
My photos are just a small subset of the master directions located here:
He has detailed photos for removing the dash, etc. The only step he did not detail was the actual bulb replacement once everything is apart, which is what I posted here.
Tom
Ok thank you much. ;)
Just did my 2001 Ody LX 130K mi and it also had 8mm bolts. The left side one had been cross-threaded by whoever did the filter the last time; I had to drill it out and replace. On the plus side, I didn't have to cut out the plastic in front of the metal bar--already gone.
I did mine with sueandroy's guide. Here it is.
http://www.odyclub.com/forums/showthread.php?s=&threadid=38974
wow
I did the cabin filter replacement today and I will say that is was quite easy and straight forward. The pics and directions were spot on, thank you. I will say that the filter was absolutely disgusting and if you haven't done this yet, you need to. This was the first time I have replaced it in 93,000 miles and I can tell you I won't wait that long again.
There's a reason they call it scheduled maintenance.:D I exceed, every year regardless of miles. On my wife's van it can be even more often. she insists on running in recirculate mode and her system smells of mold quickly.
I've been driving without a clock light ever since I got the van.
I decided that neither paying the dealer nor doing it myself is
worth it. But just yeasterday I read through this thread and
some older threads about the clock and I learned that some people fix the clock with just few taps on the dashbord.
I tried it, and after 4 fairly hard taps the clock light started to work.
I am not sure if this will last, but it is worth trying. Honda should be embarrased for all the little issues the van suffers (clock,
very poorly designed controls on the steering wheeel, all the
rattles,...).
I just finished the cabin filter replacement. I have no
experience with working on cars but this is really easy.
The first setps of pulling molding and removing kick plate
are not necessary. Just remove the right screw for glove box
(push a bit on the kick plate), be carefull so that the screw
does not fall behind the plastic (I just inserted a newspaper
to protect the screw from falling). In my case the filter was already
changed once, so no cutting of plastic. The filter was not too bad
(at lesst 3 years and 30000 miles there), I have an impression that it was inserted incorrectly.
I used Wix filter, which seems
very solid (much better than the one which I removed, it was
an aftermarket filter too), costs about $18 from RockAuto.
An experienced machanic should be able to do the job
in less that 15 minutes. Just yeasterday I had oil changed at
a dealer and they wanted $127 for the job. What a ripp-off.
Now I need to change the engine air filter (I have
never done it before myself), hope it will be as easy.
See less See more
I am new to this forum and have absolutely discovered a gold mine here. The cabin filter replacement was spot on with the aide of the pics, thank you for that. It took me about 20 minutes for the entire job. Now all I need to do is Seafoam the EGR and manifold and hopefully that will save me from spending the 800.00 for a new CAT?!?
Sorry about the $127 oil change but, didn't the dealer mention the estimated costs prior to your authorization for this service? I've received coupons for oil changes from dealer's flyers and none has approached what you were charged.
Because you tackled the cabin filter, changing the oil and filter should be a simple task for you.
He was quoting the dealer's charge for replacing the cabin filter.
Huh?
Poster quotes:
Getting late, off to hit the hay....goodnight!
Just did the cabin filter for the first time on my own. Our unit showed that it had been changed out at 38k miles - was bought as a certified used, then the dealership did it as 59k. Now the 2001 Ody has 89k. It was a fairly easy change as the bar was gone - loosened with the 8mm socket on the right side, left had been left loose enough it was easy to move out of the way to pull the access door off. Took out old filter, used a yardstick to pull the trash forward in the slot so the vacuum with the crevice tool could suck the junk out.
Got the Wix filter at the local O'Reilly's for about $24. :)
1 - 20 of 118 Posts
