Hi guys
New to the forum but hoped someone might be able to clarify.
My window regulator has broken and nawed down to where the window doesn't go up all the way.
I have been able to track down a cheap drivers side window regulator, except that it's from an RA1. Will an RA1 drivers side window regulator fit in an RA3 ?
Thanks for your help
I doubt if there's a lot here with RA3 Ody that can find out for you. Definitely there's a ton of people here with RA1. It would be great if you have pics on your RA3 window mechanism so the RA1 guys can help you.
Here in the States we had the RA1 from 1995-1997. When the RA3 came out in 1998 (and also in 1999 Isuzu Oasis) it had basically the same body, VTECH motor and minor trim differences.
If your RA3 looks like the older RA1, the regulater should fit.
Also, the RA2/RA4 with AWD has the same body- but that was JDM, we didn't get this over here!
