Hello friends. I have recently pulled a catalytic convertor code on my '06 Odyssey. Just to be sure I cleared the code and within a few days it showed up again.
My scanner said most often caused by a fuel trim running too rich on the same bank. So it looks like I am going to have to put a new cat on it, but do I need to get the fuel trims adjusted also? I have no working knowledge about fuel trims. How they work, how to adjust them, or even how to know if they need to be adjusted and what proper tolerances should be for them.
Last year I adjusted the valves, cleaned the EGR valve, replaced the PCV valve, new plugs, new wires, all new O2 sensors, 6 new fuel injectors, new valve cover gaskets, cleaned throttle body, flushed the radiator, etc.
Just parked it until I had a little time to look into it more but found out today my wife may need to drive the van to texas to pick some stuff up, so I need to figure this out.
I have no idea how to remedy the fuel trim situation. It may take an expensive high tech scanner and a knowledgable tech to do that.
I usually do all the work on my vehicles myself but this one is completely out of my knowledge level.
Any help would be appreciated by some of you more experienced guys.
